i am working with various layers that have the following coordinate system and projection:
- Coordinate system: GCS_CAPE
- Projection: Transverse_Mercator
How can I add a base map that is aligned with them? The base maps have the following features :
- Coordinate system: WGS 84
- Projection: WGS 1984 Web Mercator (auxiliary sphere)
Base maps cannot be projected.
When I try to specify a transformation for the data frame (its coordinate system is Transverse Mercator) to enable the alignment 'on-the-fly' of the base map when I add it to the map, I obtain the following message: "A datum transformation cannot be found. The data may draw with an offset". So I cannot choose any transformation,
