I have been tasked with placing images on multipatch surfaces within Arc Pro (2.3) and I am running into some issues. The multipatch 3D layer was created in AutoCAD and brought into Arc Pro. The issues are listed below:
1.) When placing a multipatch texture, the image is reversed on the surface but not in the modify>multipatch texture pane. My way around this is adding the image again and it is then displayed correctly. Am I missing something on the initial adding of the image for it to display right the first time?
2.) I would like to split or merge some of the multipatch surfaces but when I click modify and select the desired tool, I am not able to select any surfaces. Some functions under modify seem to work, like Multipatch Texture and Vertices but the ones I need do not (Merge, Split, Divide). Maybe I am missing something simple?
Any information regarding these issues would be much appreciated.
