Currently, I use the "2015 Business Analyst - Basemap Layers" as my basemap in ArcMap. I am in the process of transitioning my workflow to ArcPro and I am using the "2018 Business Analyst - Basemap" as my basemap in ArcPro . I notice that the link to the Roads layer (local roads/streets) is broken starting at 100-50k, 50-25K, etc. I try to repair the link by setting the data source - selecting the feature class (Streetscarto) in the appropriate geodatabase (see attached), but once I select the Feature Class, it states that the "Layer's data source could not be changed." and Feature Dataset/Feature Type is "Not Available". I thought that this may just be an issue with how I was referencing the 2018 Business Analyst Basemap, so I brought the 2015 Business Analyst Basemap Layer into ArcPro, and I have the same issue starting at 100-50k. I was wondering if I need to reference a different feature class/dataset in ArcPro to have access to the detailed roads?
I have attached screenshots of this issue using both the 2015 and 2018 Business Analyst basemaps. Any help would be greatly appreciated. I include detailed roads/streets on most of the maps I create, regardless of the zoom.
Lori
