I am trying to retrieve the clipping extent that I defined in the Map Properties > Clip Layers. I found there are a couple properties from CIMMap such as ClippingMode and LayersExcludedFromClipping that indicate that we are clipping layers. GetCustomFullExtent() from the MapView.Map and CIMMap classes only retrieve the custom extent defined in the Extent Map Properties, which may be different than the extent define in Clip Layers. Is there a class or method that can retrieve the actual clipping layer extent?
Thank you in advance,
Hannah
