I have added a button on it's click i want to open a widget as a dialog. i am using below code to open a widget
var wconfig =
"name": "Draw",
"label": "Draw",
"version": "2.0.1",
"uri": "widgets/Draw/Widget",
"config": "configs/Draw/config_Draw.json",
"index": 6,
"id": "widgets_Draw_Widget"
this.widgetManager.loadWidget(wconfig).then(lang.hitch(this, function(widget) {
widget.startup();
this.widgetManager.openWidget(widget);
In the console it says widget [widgets/Draw/Widget] created. but i can't see the widget.
If i use this._getPanel(wconfig,true) the widget display in left panel
_getPanel: function(widgetCfg, start) {
var def = new Deferred();
