When a user deletes a point in our Pro config, we need to delete any 'connected' links (lines) as well.
So if you have a point "J-1" connected to a link "P-1" connected to a point "J-2" and you select and delete "J-1", then I need to also delete "P-1".
I've got this implemented. However, when undo is used, that link is not restored. Right now I am using RemoveRows on the feature class table and passing in the list of objectids to remove.
I am currently using Pro SDK 2.5. With 2.6, there is the EditStarted event. Could this be used so that I could chain an operation that deletes the connected links?
Any ideas on how to better handle this use case (without going to 2.5)?
Kris
