I'm attempting to integrate THIS example into an existing widget I'm developing. So far, I've added the "Choose File" dialog that allows for navigating to a directory
Pretty simple, just added this to my widget's html:
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"jimu-btn"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>attach<SPAN class="operator token">-</SPAN>event<SPAN class="operator token">=</SPAN><SPAN class="string token">"click:toggleManualDrawTool"</SPAN><SPAN class="operator token">></SPAN>Manually Draw Boundary<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"jimu-btn finish-select"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>attach<SPAN class="operator token">-</SPAN>event<SPAN class="operator token">=</SPAN><SPAN class="string token">"click:onConfirmSelection"</SPAN><SPAN class="operator token">></SPAN>Add Selected Features to Boundary<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>br <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>br <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>form enctype<SPAN class="operator token">=</SPAN><SPAN class="string token">"multipart/form-data"</SPAN> method<SPAN class="operator token">=</SPAN><SPAN class="string token">"post"</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">"uploadForm"</SPAN><SPAN
