In web app builder I'm building an app that allows for clicks on a map and custom popup to show. I'm trying to add a second link to my popup but it appears like its adding as one long line. How can I split the one line into 2 separate lines in the one popup. Below I've included what I have so far in my MapManager.js within publishMapEvent
map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'<a href="https://survey123.arcgis.com/share/ID?center='</SPAN><SPAN class="operator token">+</SPAN> evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getLatitude</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN><SPAN class="operator token">+</SPAN> evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getLongitude</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'&field:Floor_Selection='</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>SERVICE_ID<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'_'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">"_Floor "</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string
