What is the best way to wait for this graphic to load?
Line 1, 2 and 3 are loaded (See console.log)
But line 6 suggest not yet, everything is null (see console.log)
I tried
all(features).then(function (results) {
but it didn't work...
Thanks.
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>layerSettings<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">.</SPAN>geom<SPAN class="punctuation token">)</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>layerSettings<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">)</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>layerSettings<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">.</SPAN>attr<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">esri<SPAN class="punctuation token">.</SPAN>Graphic</SPAN><SPAN class="punctuation token">(</SPAN>layerSettings<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">.</SPAN>geom<SPAN class="punctuation token">,</SPAN> layerSettings<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">,</SPAN> layerSettings<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">.</SPAN>attr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
