I have put together a python script which creates vector tile packages and publishes them to our portal. Everything appears to work fine when zoomed out past about 1:282, but upon zooming further in the data does not display at all. The application in which these packages are used requires that they be visible when zoomed far in.
I have tried to create the vtpk interactively through the ArcGIS pro UI, and it works!! - with a minimum cache scale of 1:295,828,764 and a maximum cache scale of 1:35.27, but I need it to work through the python code because we need this updated nightly and it cannot be a manual process.
this is the CreateVectorTilePackage method call from the script:
arcpy.management.CreateVectorTilePackage(map,outputPath+map.name+".vtpk" , "ONLINE", "", "INDEXED",1000000, 35.27,TileIndex,"Vector Package for application ","Vector Package for application")
If anyone has encountered similar problems or has any advice it would be appreciated!
