Does anyone know if there is a way to say use "Select By Attributes" on both a point and line feature with the same attribute, then buffer that selection with a graphic buffer?
I am basically trying to select some points and lines together and create a bounding box around them. Then I need to retrieve the bounding box coordinates.
Thanks for any help or advice
