Hi there
I am following the examples in this workbook workforce-scripts/3 - Assigning Work.ipynb at master · Esri/workforce-scripts · GitHub
Because i want to assign work to our workforce based on the predetermined zones from an existing feature layer on the map.
I have completed my code section like so:
for assignment in assignments:
contains = squadZones_df["SHAPE"].geom.contains(Geometry(assignment.geometry))
containers = squadZones_df[contains]
if not containers.empty:
squadZone = containers['OBJECTID'].iloc[0]
if squadZone == 2:
assignment.worker = squad_WSFF
assignment.status = "assigned"
assignment.assigned_date = datetime.utcnow()
elif squadZone == 5:
assignment.worker = squad_LL
elif squadZone == 8:
assignment.worker = squad_WG
elif squadZone == 11:
assignment.worker = squad_RR
elif squadZone == 16:
assignment.worker = squad_HLG
elif squadZone == 18:
assignment.worker = squad_JE
assignments = project.assignments.batch_update(assignments)However, I keep getting this error:
File "C:/Users/.../PycharmProjects/APITesting/assign_work.py", line 45, in <module>
File "C:\Users\...\AppData\Local\Continuum\anaconda3\lib\site-packages\pandas\core\frame.py", line 2970, in __getitem__
if com.is_bool_indexer(key):
File "C:\Users\...\AppData\Local\Continuum\anaconda3\lib\site-packages\pandas\core\common.py", line 130, in is_bool_indexer
raise ValueError(na_msg)
ValueError: cannot index with vector containing NA / NaN values
Can anyone help with this at all? My feature layer table looks like this:
Thanks!
