Below is the script I'm trying to run but it will not overwrite the input layer. I'm not sure what I'm doing wrong.....
<SPAN class="comment token"># Import arcpy module</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> datetime<SPAN class="punctuation token">,</SPAN> os
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"G:\****************************\Files"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ApprovedApproachesCy2.shp"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ApprovedApproachesCy2"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ApprovedApproachesCy2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Culvert_Re = 'yes' AND Date_Appro = CURRENT_DATE"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ApprovedApproachesCy2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ApprovedApproachesCy2"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Complete"</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
