I have created a feature class with the code below, but it creates it with an Unknown Spatial Reference. I know you can use other shapefiles/prj files as input to the Create Feature Class geoprocessing tool, but I'm trying to avoid creating a template for every spatial reference I might end up needing. I would rather be able to set the spatial reference from C# code after it's created. I've learned of a QueryDescription, via Database.GetQueryDescription() but the datastore is a FileGeodatabase, not an sde.
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">async</SPAN> Task<SPAN class="operator token"><</SPAN><SPAN class="keyword token">string</SPAN><SPAN class="operator token">></SPAN> <SPAN class="token function">CreateTargetPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">string</SPAN> tool_path <SPAN class="operator token">=</SPAN> <SPAN class="string token">@"management.CreateFeatureClass"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> outpath <SPAN class="operator token">=</SPAN> Project<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN>DefaultGeodatabasePath<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> args <SPAN class="operator token">=</SPAN> Geoprocessing<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MakeValueArray</SPAN><SPAN class="punctuation token">(</SPAN>outpath<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"target_point"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"POINT"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> Geoprocessing<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ExecuteToolAsync</SPAN><SPAN class="punctuation token">(</SPAN>tool_path<SPAN class="punctuation token">,</SPAN> args<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> result<SPAN class="punctuation token">.</SPAN>ReturnValue<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token">//....</SPAN>
<SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> <SPAN class="token function">CreateTargetPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> gdbPath <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FileInfo</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>Directory<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> connectionPath <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FileGeodatabaseConnectionPath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>gdbPath<SPAN class="punctuation token">.</SPAN>FullName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> geodatabase <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Geodatabase</SPAN><SPAN class="punctuation token">(</SPAN>connectionPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> featureClass <SPAN class="operator token">=</SPAN> geodatabase<SPAN class="punctuation token">.</SPAN>OpenDataset<SPAN class="operator token"><</SPAN>FeatureClass<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"target_point"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> fcDef <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDefinition</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> rowBuffer <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateRowBuffer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
rowBuffer<SPAN class="punctuation token">[</SPAN>fcDef<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetShapeField</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> centerpoint<SPAN class="punctuation token">;</SPAN>
featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateRow</SPAN><SPAN class="punctuation token">(</SPAN>rowBuffer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
viewModel<SPAN class="punctuation token">.</SPAN>TargetSite <SPAN class="operator token">=</SPAN> LayerFactory<SPAN class="punctuation token">.</SPAN>Instance<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateFeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>featureClass<SPAN class="punctuation token">,</SPAN> exportMap<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Target Site"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
