I was wondering if anyone had an idea about how to break classes by size using sdf.spatial.plot()
The default class break method is by color, however, there should be a way to break classes by size. I searched the guide and other posts, and have yet to find the proper code. Here is what I have right now:
sdf = pd.DataFrame.spatial.from_layer(screenings_feature_layer)
sdf.spatial.plot(map_widget = map1, # Map widget variable
renderer_type = 'c', # Type of Renderer ("s", "c", "u", etc.)
method = "esriClassifyEqualInterval", # Classification Scheme
class_count = 5, # Number of classes
col = 'Number_of_', # Field of interest
min_value = 1, # Lower bound of data
max_value = max(sdf['Number_of_']), # Upper bound of data
default_symbol = None, # Refers to "Other" values not in specified range
alpha = 0.7)
I've tried min_size = , max_size = , and others.
Let me know if you know the answer! Thanks so much!
