What is the pathway for AppStudio with regards the release (beta or otherwise) of Quartz?
I saw a post in the Qt space indicating a beta for Qt around June. Will AppStudio release an update at the same time? If so and it is a beta, will it be able to be installed alongside existing version or should we expect to deploy to a dev machine while in beta?
Once installed, will projects created using the existing runtime version still open and work with no changes, or, once AppStudio is upgraded, will we need to refactor code before it will compile and run.
Am trying to plan ahead and anticipate any possible issues.
-Paul
