I'm the beginner of Arcgis pro.
Where is the code wrong ?
arcpy.env.workspace = "C:\Projecct\SketchUp"
arcpy.Import3DFiles_3d("geo.skp", "Test.gdb/AddisSheraton", 'ONE_FILE_ONE_FEATURE','' , 'Z_IS_UP', 'SKP' )
Runtime error
File "<string>", line 2, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\ddd.py", line 1008, in Import3DFiles
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\ddd.py", line 1005, in Import3DFiles
retval = convertArcObjectToPythonObject(gp.Import3DFiles_3d(*gp_fixargs((in_files, out_featureClass, root_per_feature, spatial_reference, y_is_up, file_suffix, in_featureClass, symbol_field), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 500, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 050038: No Valid Files
CreateFeatureClassName: The workspace Test.gdb does not exist.
Failed to execute (Import3DFiles).
