Hello, I have a list of points and a list of polygons both in a separate shape files. I am trying to write a ArcPy script to loop through the points, and then the polygons respectively and tell me when a point is within a polygon. I have tried both the contains and touches methods on polygons but haven't had any luck. Any help would be appreciated. So far I have the following:import arcpy pointFeatureClass = "C:\\Data\\POINTS2.dbf" pointFieldList = arcpy.ListFields(pointFeatureClass) for field in pointFieldList: curField = field.name arcpy.AddMessage(curField) ptRows = arcpy.SearchCursor("C:\\Data\\POINTS2.dbf", "", "", "CID;Shape","CID;Shape") for ptRow in ptRows: #Now loop through poly's testing for intersect shpRows = arcpy.SearchCursor("C:\\Data\\counties.shp", "", "", "NAME;Shape","NAME;Shape") for shpRow in shpRows: #arcpy.AddMessage("Checking for point "+ str(ptRow.CID) +" in: " + shpRow.NAME) if shpRow.Shape.touches(ptRow.Shape): arcpy.AddMessage("Got it: " + shpRow.NAME)
