This question is a continuation of my last one: Query Features by Category and Keyword
The app so far has two drop-downs. The user can query by categories and query by keywords.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Recycling Map<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.15/esri/themes/light/main.css"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.15/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#viewDiv <SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
#infoDiv <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> white<SPAN class="punctuation token">;</SPAN>
color<SPAN class="punctuation token">:</SPAN> black<SPAN class="punctuation token">;</SPAN>
padding<SPAN class="punctuation token">:</SPAN> 6px<SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> 440px<SPAN class="punctuation token">;</SPAN>
#titleDiv <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="punctuation token">:</SPAN> 10px<SPAN class="punctuation token">;</SPAN>
#titleText <SPAN class="punctuation token">{</SPAN>
font<SPAN class="operator token">-</SPAN>size<SPAN class="punctuation token">:</SPAN> 20pt<SPAN class="punctuation token">;</SPAN>
font<SPAN class="operator token">-</SPAN>weight<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">60</SPAN><SPAN class="punctuation token">;</SPAN>
padding<SPAN class="operator token">-</SPAN>bottom<SPAN class="punctuation token">:</SPAN> 10px<SPAN class="punctuation token">;</SPAN>
#results <SPAN class="punctuation token">{</SPAN>
font<SPAN class="operator token">-</SPAN>weight<SPAN class="punctuation token">:</SPAN> bolder<SPAN class="punctuation token">;</SPAN>
padding<SPAN class="operator token">-</SPAN>top<SPAN class="punctuation token">:</SPAN> 10px<SPAN class="punctuation token">;</SPAN>
#category<SPAN class="punctuation token">,</SPAN>
#keyword <SPAN class="punctuation token">{</SPAN>
margin<SPAN class="operator token">-</SPAN>top<SPAN class="punctuation token">:</SPAN> 8px<SPAN class="punctuation token">;</SPAN>
margin<SPAN class="operator token">-</SPAN>bottom<SPAN class="punctuation token">:</SPAN> 8px<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/geometryEngine"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Graphic"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN>
MapView<SPAN class="punctuation token">,</SPAN>
FeatureLayer<SPAN class="punctuation token">,</SPAN>
GraphicsLayer<SPAN class="punctuation token">,</SPAN>
geometryEngine<SPAN class="punctuation token">,</SPAN>
Graphic
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> catTypeSelect <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"category"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> keyTypeSelect <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"keyword"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> filterButton <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"SelectBtn"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Recycling Locations View</SPAN>
<SPAN class="keyword token">var</SPAN> recycleLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// autocasts as new PortalItem()</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"227061be60a14cc89946a978b440d227"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// GraphicsLayer for displaying results</SPAN>
<SPAN class="keyword token">var</SPAN> resultsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray"</SPAN><SPAN class="punctuation token">,</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>recycleLayer<SPAN class="punctuation token">,</SPAN> resultsLayer<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">87.95</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">41.47</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"infoDiv"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-left"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// query all features from the Recycle layer</SPAN>
view
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> recycleLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> recycleLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> recycleLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getValues<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>getUniqueValues<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>addToSelect<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// return an array of all the values in the</SPAN>
<SPAN class="comment token">// USER_Categ and USER_Keyword fields of the Recycle layer</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getValues</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> values <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">{</SPAN>
USER_Categ<SPAN class="punctuation token">:</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>USER_Categ<SPAN class="punctuation token">,</SPAN>
USER_Keywo<SPAN class="punctuation token">:</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>USER_Keywo
<SPAN class="keyword token">return</SPAN> values<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// return an array of unique values in</SPAN>
<SPAN class="comment token">// the keyword and category fields of the Recycle layer</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">getUniqueValues</SPAN><SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> uniqueKeyValues <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> uniqueCatValues <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> keyVal <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>USER_Keywo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> catVal <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>USER_Categ<SPAN class="punctuation token">.</SPAN><SPAN class="token function">split</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
catVal<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>val1<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>
<SPAN class="punctuation token">(</SPAN>uniqueCatValues<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token"><</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">||</SPAN> uniqueCatValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>val1<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">===</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN>
val1 <SPAN class="operator token">!==</SPAN> <SPAN class="string token">""</SPAN>
uniqueCatValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>val1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
keyVal<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>val2<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">(</SPAN>uniqueKeyValues<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token"><</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="operator token">||</SPAN> uniqueKeyValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>val2<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">===</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">&&</SPAN>
val2 <SPAN class="operator token">!==</SPAN> <SPAN class="string token">""</SPAN>
uniqueKeyValues<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>val2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
uKeyVals<SPAN class="punctuation token">:</SPAN> uniqueKeyValues<SPAN class="punctuation token">,</SPAN>
uCatVals<SPAN class="punctuation token">:</SPAN> uniqueCatValues
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Add the unique values to the category type</SPAN>
<SPAN class="comment token">// select element. This will allow the user</SPAN>
<SPAN class="comment token">// to filter categorys by type.</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addToSelect</SPAN><SPAN class="punctuation token">(</SPAN>values<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
values<SPAN class="punctuation token">.</SPAN>uCatVals<SPAN class="punctuation token">.</SPAN><SPAN class="token function">sort</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN>uCatVals<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> option <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"option"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
option<SPAN class="punctuation token">.</SPAN>text <SPAN class="operator token">=</SPAN> value<SPAN class="punctuation token">;</SPAN>
catTypeSelect<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>option<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN>uKeyVals<SPAN class="punctuation token">.</SPAN><SPAN class="token function">sort</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
values<SPAN class="punctuation token">.</SPAN>uKeyVals<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>value<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
keyTypeSelect<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>option<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">setDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set the definition expression on the recycle</SPAN>
<SPAN class="comment token">// layer to reflect the selection of the user</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setDefinitionExpression</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> sqlExp <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>catTypeSelect<SPAN class="punctuation token">.</SPAN>selectedIndex <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
sqlExp <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">"USER_Categ LIKE '%"</SPAN> <SPAN class="operator token">+</SPAN> catTypeSelect<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">[</SPAN>catTypeSelect<SPAN class="punctuation token">.</SPAN>selectedIndex<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">+</SPAN> <SPAN class="string token">"%'"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>keyTypeSelect<SPAN class="punctuation token">.</SPAN>selectedIndex <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>sqlExp <SPAN class="operator token">===</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
sqlExp <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">"USER_Keywo LIKE '%"</SPAN> <SPAN class="operator token">+</SPAN> keyTypeSelect<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">[</SPAN>keyTypeSelect<SPAN class="punctuation token">.</SPAN>selectedIndex<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">+</SPAN> <SPAN class="string token">"%'"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
sqlExp <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">" AND USER_Keywo LIKE '%"</SPAN> <SPAN class="operator token">+</SPAN> keyTypeSelect<SPAN class="punctuation token">.</SPAN>options<SPAN class="punctuation token">[</SPAN>keyTypeSelect<SPAN class="punctuation token">.</SPAN>selectedIndex<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>value <SPAN class="operator token">+</SPAN> <SPAN class="string token">"%'"</SPAN><SPAN class="punctuation token">;</SPAN>
recycleLayer<SPAN class="punctuation token">.</SPAN>definitionExpression <SPAN class="operator token">=</SPAN> sqlExp<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>recycleLayer<SPAN class="punctuation token">.</SPAN>visible<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
recycleLayer<SPAN class="punctuation token">.</SPAN>visible <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">queryForGeometries</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Get all the geometries of the recycle layer</SPAN>
<SPAN class="comment token">// the createQuery() method creates a query</SPAN>
<SPAN class="comment token">// object that respects the definitionExpression</SPAN>
<SPAN class="comment token">// of the layer</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">queryForGeometries</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> rQuery <SPAN class="operator token">=</SPAN> recycleLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createQuery</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> recycleLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>rQuery<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
rGeometries <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> rGeometries<SPAN class="punctuation token">;</SPAN>
filterButton<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// set a new definitionExpression on the recycle layer</SPAN>
<SPAN class="comment token">// catTypeSelect.addEventListener("change", function () {</SPAN>
<SPAN class="comment token">// var type = event.target.value;</SPAN>
<SPAN class="comment token">// setDefinitionExpression(type, "cat");</SPAN>
<SPAN class="comment token">// });</SPAN>
<SPAN class="comment token">// keyTypeSelect.addEventListener("change", function () {</SPAN>
<SPAN class="comment token">// setDefinitionExpression(type, "key");</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"titleDiv"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"infoDiv"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"drop-downs"</SPAN><SPAN class="operator token">></SPAN>
Select Category <SPAN class="punctuation token">(</SPAN>leave blank <SPAN class="keyword token">if</SPAN> searching by Keyword<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="operator token"><</SPAN>select id<SPAN class="operator token">=</SPAN><SPAN class="string token">"category"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>select<SPAN class="operator token">></SPAN>
Select Keyword<SPAN class="punctuation token">:</SPAN>
<SPAN class="operator token"><</SPAN>select id<SPAN class="operator token">=</SPAN><SPAN class="string token">"keyword"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>select<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>button id<SPAN class="operator token">=</SPAN><SPAN class="string token">"SelectBtn"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-button esri-button--secondary"</SPAN><SPAN class="operator token">></SPAN>Search<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>button<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"results"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"titleDiv"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"titleText"</SPAN><SPAN class="operator token">></SPAN>Green Guide<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div<SPAN class="operator token">></SPAN>Easy Ways To Be More Green<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Now I'd like to filter the categories and keywords based on two fields in the attribute table, USER_IsRes and USER_IsBus (residential and business). The values are either TRUE or FALSE-- Feature Layer View. I'm able to use a sample and loosely get that to function with the USER_IsRes field.
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Filter features by attribute <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.15</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
#res<SPAN class="operator token">-</SPAN>filter <SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> 160px<SPAN class="punctuation token">;</SPAN>
visibility<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>res<SPAN class="operator token">-</SPAN>item <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="punctuation token">:</SPAN> 12px<SPAN class="punctuation token">;</SPAN>
text<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> center<SPAN class="punctuation token">;</SPAN>
vertical<SPAN class="operator token">-</SPAN>align<SPAN class="punctuation token">:</SPAN> baseline<SPAN class="punctuation token">;</SPAN>
cursor<SPAN class="punctuation token">:</SPAN> pointer<SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> 40px<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>res<SPAN class="operator token">-</SPAN>item<SPAN class="punctuation token">:</SPAN>focus <SPAN class="punctuation token">{</SPAN>
background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> dimgrey<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN>res<SPAN class="operator token">-</SPAN>item<SPAN class="punctuation token">:</SPAN>hover <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"esri/widgets/Expand"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">,</SPAN> Map<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> Expand<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> floodLayerView<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// flash flood warnings layer</SPAN>
<SPAN class="keyword token">const</SPAN> layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"USER_IsRes"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">const</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray-vector"</SPAN><SPAN class="punctuation token">,</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>layer<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">const</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">98</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">40</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4</SPAN>
<SPAN class="keyword token">const</SPAN> resNodes <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelectorAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="template-string token"><SPAN class="string token">`.res-item`</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> resElement <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"res-filter"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// click event handler for res choices</SPAN>
resElement<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> filterByres<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// User clicked on Winter, Spring, Summer or Fall</SPAN>
<SPAN class="comment token">// set an attribute filter on flood warnings layer view</SPAN>
<SPAN class="comment token">// to display the warnings issued in that res</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">filterByres</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> selectedres <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"data-res"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
floodLayerView<SPAN class="punctuation token">.</SPAN>filter <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
where<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"USER_IsRes = '"</SPAN> <SPAN class="operator token">+</SPAN> selectedres <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">,</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenLayerView</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>layerView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// flash flood warnings layer loaded</SPAN>
<SPAN class="comment token">// get a reference to the flood warnings layerview</SPAN>
floodLayerView <SPAN class="operator token">=</SPAN> layerView<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set up UI items</SPAN>
resElement<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>visibility <SPAN class="operator token">=</SPAN> <SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> resExpand <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> resElement<SPAN class="punctuation token">,</SPAN>
expandIconClass<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esri-icon-filter"</SPAN><SPAN class="punctuation token">,</SPAN>
group<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"top-left"</SPAN>
<SPAN class="comment token">//clear the filters when user closes the expand widget</SPAN>
resExpand<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"expanded"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>resExpand<SPAN class="punctuation token">.</SPAN>expanded<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
floodLayerView<SPAN class="punctuation token">.</SPAN>filter <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>resExpand<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-left"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"res-filter"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"esri-widget"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"res-item visible-res"</SPAN> data<SPAN class="operator token">-</SPAN>res<SPAN class="operator token">=</SPAN><SPAN class="string token">"TRUE"</SPAN><SPAN class="operator token">></SPAN>True<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"res-item visible-res"</SPAN> data<SPAN class="operator token">-</SPAN>res<SPAN class="operator token">=</SPAN><SPAN class="string token">"False"</SPAN><SPAN class="operator token">></SPAN>False<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"titleText"</SPAN><SPAN class="operator token">></SPAN>Flash Floods by res<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div<SPAN class="operator token">></SPAN>Flash Flood Warnings <SPAN class="punctuation token">(</SPAN><SPAN class="number token">2002</SPAN> <SPAN class="operator token">-</SPAN> <SPAN class="number token">2012</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But, how do I incorporate the filter (preferably client side since they say it's faster) into the app? Once the user has either a keyword or category selected I want there to be a way to filter with either Residential or Business.
In the end, the selection methods should more or less mirror this page: Will County EEC Mobile Site
