Hi all,
I'am working on Visual Studio 2017 Community 15.9.13 with Xamarin 4.12.3.83 and Xamarin Android SDK 9.1.7.0.
I use ArcGIS runtime SDK for .NEt 100.5.0.
I want to compile and run the "Feature layer selection" or other similar code in the Sample Code section of the ArcGIS for Developer site.
When the target Android version is less then 9.0 (Pie) version, all functions well.
With Android 9.0 version the app is compiled and deployed correctly on my device while it crashes when it tries to execute an await function.
For axample:
Uri featureServiceUri = new Uri("http://sampleserver6.arcgisonline.com/arcgis/rest/services/DamageAssessment/FeatureServer/0");
var featureTable = new ServiceFeatureTable(featureServiceUri);
featureLayer = new FeatureLayer(featureTable);
await _featureLayer.LoadAsync(); // at this point the app crashes
When I catch the error, these are the Exception properties results:
HResult: -2146233088
InnerException: Java.IO.IOException: Cleartext HTTP traffic to sampleserver6.arcgisonline.com not permitted
Message: One or more errors occurred.
Source: mscorlib
StackTrace: at Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler+ArcGISClientHandlerInternal+<>c__DisplayClass14_1.<SendAsync>b__0 (System.Threading.Tasks.Task`1[TResult] t) [0x00033] in C:\daily_r\api_xam\dotnet\api\src\Esri.ArcGISRuntime\Esri.ArcGISRuntime.Shared\Http\ArcGISHttpClientHandler.cs:703
at System.Threading.Tasks.ContinuationResultTaskFromResultTask`2[TAntecedentResult,TResult].InnerInvoke () [0x00024] in <d4a23bbd2f544c30a48c44dd622ce09f>:0
at System.Threading.Tasks.Task.Execute () [0x00000] in <d4a23bbd2f544c30a48c44dd622ce09f>:0
--- End of stack trace from previous location where exception was thrown ---
at Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler+ArcGISClientHandlerInternal+<SendAsync>d__14.MoveNext () [0x008b5] in C:\daily_r\api_xam\dotnet\api\src\Esri.ArcGISRuntime\Esri.ArcGISRuntime.Shared\Http\ArcGISHttpClientHandler.cs:879
at System.Net.Http.HttpClient+<SendAsyncWorker>d__49.MoveNext () [0x000
ca] in <25ebe1083eaf4329b5adfdd5bbb7aa57>:0
at Esri.ArcGISRuntime.Internal.RequestRequiredHandler+<IssueRequestAndRespond>d__14.MoveNext () [0x004f9] in C:\daily_r\api_xam\dotnet\api\src\Esri.ArcGISRuntime\Esri.ArcGISRuntime.Shared\Internal\RequestRequiredHandler.cs:245
at FeatureLayerSelectionTest.MainActivity+<Initialize>d__4.MoveNext () [0x00115] in C:\VisualStudio\Xamarin\Progetti\FeatureLayerSelectionTest\FeatureLayerSelectionTest\MainActivity.cs:82
TargetSite: Void Throw()
Can someone help me?
Many thanks
Regards
Massimo
