I am looking into the various options for deploying ArcGIS Enterprise in a small municipality.
Can someone confirm if it is possible to publish a feature service from a workgroup geodatabase registered with ArcGIS Enterprise Workgroup to AGOL or Portal with editing capabilities?
Can this data then be used in Collector, either via Portal or AGOL?
If both are true, do the connections coming from Portal/AGOL/Collector count towards the 10 simultaneous connections available to the workgroup geodatabase?
Finally, is it possible to create a view in Portal or AGOL based on this feature service, which would allow the bypass of the concurrent connections for viewers only?
