Hey everybody,I am have the following map, that creates a point on load. Now I would like to add a popup box that is already opened on load, where I can put an address in. So when the map loads it shows a point with an open popup box pointing to the point. What is the best way to do that?Here is my code:<!DOCTYPE html> <html> <head> <title>Create a Map</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #mapDiv{ padding: 0; margin: 0; height: 100%; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/geometry/Point", "esri/graphic", "dojo/on", "dojo/dom", "dojo/domReady!" ], function( Map, SimpleMarkerSymbol, SimpleLineSymbol, Color, Point, Graphic, on, dom ) { map = new Map("mapDiv", { center: [-80.719892, 28.303518], zoom: 16, basemap: "topo" }); on(map, "load", addGraphic); var sfs = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 1), new Color([0,255,0,0.25]) ) function addGraphic(){ var singlePoint = new Point([-80.719892, 28.303518]) var gra = new Graphic(singlePoint,sfs); map.graphics.add(gra); } }); </script> </head> <body class="claro"> <div id="mapDiv"></div> </body> </html>Thanks!Tim
