When publishing a Web Tool from ArcPro 2.5.1, I often times get no response when clicking on the Publish button after first Analyzing the result. What I see is that an .sddraft is being generated without a local toolbox OnPremisePath in the resources of the sddraft. How can I ensure that the OnPremisePath in the sddraft gets populated and the Web Tool successfully stages and publishes?
Successfull Publish sddraft Resource section:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resources</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:ArrayOfSVCResource<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>SVCResource</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:SVCResource<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>xyz-xyz-xyz-xyz<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>clippedsources.xml<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Name</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>OnPremisePath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>C:\Users\xyz\AppData\Local\Temp\ArcGISProTemp25188\FEMAFloodZoneA.tbx<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>OnPremisePath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>StagingPath</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>StagingPath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ServerPath</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ServerPath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>InPackagePath</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>InPackagePath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>OnServerName</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>OnServerName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ClientName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>xyz-xyz<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ClientName</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>CIMPath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>CIMPATH=clippedsources/clippedsources.xml<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>CIMPath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>RepositoryID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>RepositoryID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>SVCResource</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resources</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>UnSuccessfull Publish sddraft Resource section:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>OnPremisePath</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>OnPremisePath</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
