About to migrate a sandbox instance of ArcGIS Enterprise 10.6.1. It's never been backed up before to my knowledge. Running webgisdr gives the following output:
Starting the WebGIS DR utility.
The configuration and base backup time in the current Web GIS
Portal: https://web.domain.ca/portal at 11/28/19 10:18 AM
|-- Hosting Server: https://web.domain.ca/server at 11/28/19 10:18 AM
| |-- Relational Data Store: https://internal-gis.cloud.domain.ca:2443/arcgis
Starting the backup process with the WebGIS DR utility.
Starting the backup for Portal for ArcGIS:
Url: https://web.domain.ca/portal.
Starting the backup for ArcGIS Server:
Url: https://web.domain.ca/server.
Starting the backup for ArcGIS Data Store:
Url: https://internal-gis.cloud.domain.ca:2443/arcgis.
The following ArcGIS Data Store has been backed up successfully:
The backup of ArcGIS Data Store has completed in 00hr:00min:07sec.
Failed to back up the ArcGIS Server:
{"code":500,"messages":["Export operation failed. Method argument cannot be null."],"status":"error"}
The following Portal for ArcGIS has been backed up successfully:
The backup of Portal for ArcGIS has completed in 00hr:16min:02sec.
The backup of Web GIS components has completed in 00hr:16min:10sec.<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>"Method argument cannot be null" is the only error in the server log as well. Thoughts?
