Aaron,
How is editing going at SQL2014? Are you at SP1? Our organization is looking at moving to this soon.
Just to wake up this thread...we are using 10.2.2, SQL2012 SP2 and SDE with DBO schema and direct connect. We have been fighting this issue for almost one year with no resolution. The SDE Geometry type seems to be a culprit and yes we heard SDEbinary was going away at 10.4. It seems worse when the data is within a feature data set. We are still testing different variations. I have recently set up a test environment with 10.3.1 and SQL2014. If anyone has more info, please drop a note. Thanks!
Hmm, that's not good. Did they mention that SDEBinary was going away in 10.3? We are using 10.2.2. SDEBinary seemed to be our best solution to the performance problems we were having. It may be a while until I update to 10.3 if this is the case.
We migrated to SDEGeometry because it is ESRI's standard and we were informed that SDEBinary was going away. We continue to have performance problems and are working with ESRI to try and resolve the problems, but we still don't have a clear path forward. We are running 10.2.1 currently.
Hi, I know this is a little old, but I was having some of the same issues as you were. I was wondering why you decided to migrate from SDEBinary to SDEGeometry. I did the opposite and migrated to SDEBinary and noticed significant performance improvement.
We have a 32 core SQL Server with a MAXDOP setting of 6, which was set after we upgraded from SDE 10.0 to 10.2.1 and migrated our data from SDE_Binary to SDE_Geometry. We have started rebuilding our spatial indexes on our large feature classes, but are still experiencing SEVERE slowness while editing, especially when snapping. It seems to be worse while multiple users are connected and actively editing. The slowness is intermittent throughout the day, and slowness can be experienced by one user and not another during the same time period. If we export our data to a file geodatabase we do not experience slowness while snapping and panning.
Has anyone else solved the slowness problem or received a good answer from ESRI?
Ever since we've gone to 10.1 with the direct connect we've had nothing but problems. We've had multiple duplicate key errors and countless snapping issues. The snapping will just at times quit working all together, but strangest we've encountered is snapping issues with a large lake layer. It's located on the SDE and anytime a person goes to edit it the snapping gets killed until a compression is done. I would get it if we did a lot of edits, but all it takes is moving one point in this file and snapping dies for every other layer until a compression is done. We have very few people that look at the layers on the SDE and only two edit on it but we need it to work. Before we upgraded from 10 to 10.1 it worked fine. We have moved several points but haven't really added many so the file size hasn't changed much from then to now.
I've been having issues when editing a version 10 geodatabase in ArcGIS 10.1 from the network. Editing a version 9.3 seems to be fine. With ArcGIS 10, I was having zero issues editing from the network. Basically, selecting anything has a noticeable delay. Moving anything results in at least a 10 second delay. Editing the same data on my local results in zero problems. I called tech support and they initially blamed it on the network. Well, 2 days prior, it worked fine on the same network. There were no changes made to the network, only to the upgrade of version 10 to 10.1. We then tried renaming the normal.mxt and the esri folders in the registry. That didn't work either.Has anyone experienced this in 10.1? It's a bit frustrating, because we really need this to work from the network. I am editing on my local right now as a temp fix, but eventually that won't work.Thanks,Robb
Problem signature: Problem Event Name: APPCRASH Application Name: ArcMap.exe Application Version: 10.1.1.3143 Application Timestamp: 5058f74e Fault Module Name: StackHash_4183 Fault Module Version: 6.1.7601.17514 Fault Module Timestamp: 4ce7ba58 Exception Code: c0000374 Exception Offset: 000ce653 OS Version: 6.1.7601.2.1.0.18.10 Locale ID: 1033 Additional Information 1: 4183 Additional Information 2: 418393d3a499c8ae8ed0a6df247c128b Additional Information 3: c8cd Additional Information 4: c8cd612dd071564a925536fa3384b159 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
Description: Stopped working Problem signature: Problem Event Name: APPCRASH Application Name: ArcMap.exe Application Version: 10.1.1.3143 Application Timestamp: 5058f74e Fault Module Name: mscorwks.dll Fault Module Version: 2.0.50727.5420 Fault Module Timestamp: 4ca2b820 Exception Code: c0000005 Exception Offset: 00163298 OS Version: 6.1.7601.2.1.0.18.10 Locale ID: 1033 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und mehr. Neu hier? Registriere ein kostenloses Konto.
