I'm using this work around:
var v1 = await QueuedTask.Run(() => Geoprocessing.MakeValueArray(l1, null, units));
await Geoprocessing.ExecuteToolAsync("analysis.Buffer", v1).ContinueWith(async t =>
var fillBuffLayer = DeltaLayer.Map.Layers.Where(l =>
var b = l as FeatureLayer;
return (b != null) && (b.LabelClasses[0].WhereClause == "[BUFF_DIST]");
}).FirstOrDefault();
var buffLayer1 = (FeatureLayer)fillBuffLayer;
if (buffLayer1 != null)
var simpleValueRenderer =
(CIMSimpleRenderer)buffLayer1.CreateRenderer(BufferFillRendererDefinition));
buffLayer1.SetRenderer(simpleValueRenderer);
}However it takes long time to execute and flickers ugly...
The second issue I face: the above code continue like this:
if (l2 != null)
var v2 = await QueuedTask.Run(() => Geoprocessing.MakeValueArray(l2, null, units));
await Geoprocessing.ExecuteToolAsync("analysis.Buffer", v2);
var emptyBuffLayer = DeltaLayer.Map.Layers.Where(l =>
return (b != null) && !Equals(b, buffLayer1) && (b.LabelClasses[0].WhereClause == "[BUFF_DIST]");
var buffLayer2 = (FeatureLayer)emptyBuffLayer;
if (buffLayer2 != null)
(CIMSimpleRenderer)(buffLayer2.CreateRenderer(BufferEmptyRendererDefinition));
buffLayer2.SetRenderer(simpleValueRenderer);
}and it is called after a Select and a Zoom to a feature which contains the points from the arrays l1 and l2.
With or without this code, after Select/Zoom, the map remains busy for a long lime (like in 5-10 seconds - why?!)
...Most of the times it fails either the points in l1 or l2 (IReadOnlyCollection<object>), or both, or fails to change the renter. However, some times (quite seldom) it works well...
Would it be because of the busy time on the mapView?
(And - third: Intellisesnse reports closures for l1, l2 and this on both ContinueWith...)
