I'm working with a basic polygon and point feature class in the same FGDB in the most recent ArcPro 2.2.
Each polygon contains points in a grid, but for some reason when I delete points and recreate them I can't see the changes. The changes ARE being applied to the featureclass, but it will not visually update. I can even select the points where they've been created (but invisible).
Refreshing the map with F5 doesn't help, nor does clearing the cache in the point layer. I'm also usingΒ MapView.Active.Redraw(true); but again no luck. surely there's a way of force updating the layer?
