I'm trying to create a button that runs a python script.I've been following the help and have reached the point where I test an add-in:http://resources.arcgis.com/en/help/main/10.1/index.html#/Testing_an_add_in/014p00000026000000/I run the script makeaddin.py as stated in step 1 and get this error:Traceback (most recent call last): File "C:\E1B8\ScriptTesting\MISC\Tool\makeaddin.py", line 5, in <module> current_path = os.path.dirname(os.path.abspath(__file__))NameError: name '__file__' is not definedShould __file__ been replaced with a path, and somehow that didn't happen for me? If so, can I add it manually just to make things easy on myself?makeaddin.py:import os import re import zipfile current_path = os.path.dirname(os.path.abspath(__file__)) out_zip_name = os.path.join(current_path, os.path.basename(current_path) + ".esriaddin") BACKUP_FILE_PATTERN = re.compile(".*_addin_[0-9]+[.]py$", re.IGNORECASE) def looks_like_a_backup(filename): return bool(BACKUP_FILE_PATTERN.match(filename)) with zipfile.ZipFile(out_zip_name, 'w', zipfile.ZIP_DEFLATED) as zip_file: for filename in ('config.xml', 'README.txt', 'makeaddin.py'): zip_file.write(os.path.join(current_path, filename), filename) dirs_to_add = ['Images', 'Install'] for directory in dirs_to_add: for (path, dirs, files) in os.walk(os.path.join(current_path, directory)): archive_path = os.path.relpath(path, current_path) found_file = False for file in (f for f in files if not looks_like_a_backup(f)): archive_file = os.path.join(archive_path, file) print archive_file zip_file.write(os.path.join(path, file), archive_file) found_file = True if not found_file: zip_file.writestr(os.path.join(archive_path, 'placeholder.txt'), "(Empty directory)")
The script I'm trying to turn into a button (at this stage, Tool_addin.py):import arcpy import pythonaddins def selecttoDQ(): #do things## #################### class ListLayers(object): """Implementation for Tool_addin.btn1 (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): selecttoDQ()
Thanks!
