Hi guys,
Looking to setup a one-way replication of our Main Database (SDE - Parent) to a file Geodatabase (child)
The Main SDE instance will be where all the edits are done on one server.
The FGDB is simply a replica read/only instance which will sit on our WAN on a different server in another country.
After reading the ArcGIS Help guidelines it seems pretty straight forward, which is why I am asking if there's any other "catch" with regard to setting up this simple replication ? Anyone had experience is this situation?
I understand this statement from the Help is a prerequisite for the replication to take place:
Two-way and one-way parent-to-child replicas have these additional requirements:
- Each dataset must have a GlobalID column. This column is used to maintain row uniqueness across geodatabases.
- All spatial data must be stored in a high-precision spatial reference.
anything else I need to be aware of ?
thanks,
Tim
