Since I update arcgis 104.1 to 10.5.1, I have an issue when i want to generate token :
parameters <SPAN class="operator token">=</SPAN> urllib<SPAN class="punctuation token">.</SPAN>urlencode<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">'username'</SPAN> <SPAN class="punctuation token">:</SPAN> username<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'password'</SPAN> <SPAN class="punctuation token">:</SPAN> password<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'client'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'referer'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'referer'</SPAN><SPAN class="punctuation token">:</SPAN> portalUrl<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'expiration'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">60</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'f'</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'json'</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
response <SPAN class="operator token">=</SPAN> urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>portalUrl <SPAN class="operator token">+</SPAN> <SPAN class="string token">'/sharing/rest/generateToken?'</SPAN><SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
jsonResponse <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="string token">'token'</SPAN> <SPAN class="keyword token">in</SPAN> jsonResponse<SPAN class="punctuation token">:</SPAN>
self<SPAN class="punctuation token">.</SPAN>token <SPAN class="operator token">=</SPAN> jsonResponse<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'token'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">return</SPAN> self<SPAN class="punctuation token">.</SPAN>token
<SPAN class="keyword token">elif</SPAN> <SPAN class="string token">'error'</SPAN> <SPAN class="keyword token">in</SPAN> jsonResponse<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>jsonResponse<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'error'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'message'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> detail <SPAN class="keyword token">in</SPAN> jsonResponse<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'error'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'details'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>detail<SPAN class="punctuation token">)</SPAN>
sys<SPAN class="punctuation token">.</SPAN>exit<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN> ValueError<SPAN class="punctuation token">,</SPAN> e<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'An unspecified error occurred.'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>IOError: [Errno socket error] [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)
Do you have any idea to solve this issue ?
Thx.
