Hi All or Robert Scheitlin, GISP ,
I am needing help with the ListView widget. We are needing it to display only unique values from a feature layer field as well as filter and zoom to from the selected list item. here is my widget.js code. I changed the outfield to the config.titleField and was able to pass only unique values to the list however this changed the click function. See widget.js below I also attached the full zip.
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'jimu/BaseWidget'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dojo/_base/lang'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dojo/Deferred'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dgrid/OnDemandList'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dgrid/Selection'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/store/Memory"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>declare<SPAN class="punctuation token">,</SPAN> BaseWidget<SPAN class="punctuation token">,</SPAN>
lang<SPAN class="punctuation token">,</SPAN> Deferred<SPAN class="punctuation token">,</SPAN>
OnDemandList<SPAN class="punctuation token">,</SPAN> Selection<SPAN class="punctuation token">,</SPAN> Memory<SPAN class="punctuation token">,</SPAN>
Query<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//To create a
