I have a project collecting noxious weed treatment data using QuickCapture to collect points. Currently I've configured QuickCapture to have multiple buttons which each record a different species. The buttons record a point and populate the species code and date fields. The species code is populated correctly when uploaded to AGOL. However when data are reviewed in QuickCapture prior to sending it to AGOL, they show incorrect data for the species code field. When reviewed the data always show the same species in the species code field regardless of which button is pressed to record data. This problem prevents the field workers who are collecting data from reliably reviewing and editing their data before sending to AGOL.
Since the data are correct when sent to AGOL I'm guessing it's a problem within QuickCapture itself. If it's not a bug, what can I do to fix it?
