Hello, I am attempting to execute Area Solar Radiation in a stand-alone python script (shown below). The basis for the script was provided in the ESRI tool help. I made a few adjustments to this template by adjusting a few of the local variables and adding try/except etc.The problem is that when I execute the script, it runs for about a minute then fails with an ERROR 999999 (also shown below in quoted script output).Does anyone have an idea on why this may be occurring?# Name: SolarRad_MayJuly.py # Description: Derives incoming solar radiation from a raster surface. # Outputs a global radiation raster and optional direct, diffuse and direct duration rasters # for a specified time period. (May to July). # # Requirements: Spatial Analyst Extension # Import system modules import arcpy, time from arcpy import env from arcpy.sa import * # Set environment settings env.workspace = "D:/Projects/Tasks/02_SpatialInputs/SolarRad/work/MayJulyOutput" # Check out the ArcGIS Spatial Analyst extension license arcpy.CheckOutExtension("Spatial") # Set local variables inRaster = "D:/Projects/Tasks/02_SpatialInputs/Geomorph/ElevationSlope/elev" latitude = 37.1567 skySize = 200 timeConfig = TimeMultipleDays(2012, 121, 212) dayInterval = 14 hourInterval = 1 zFactor = 1 calcDirections = 32 zenithDivisions = 8 azimuthDivisions = 8 diffuseProp = 0.3 transmittivity = 0.5 outDirectRad = "" outDiffuseRad = "" outDirectDur = "" print time.asctime(time.localtime()) print "Running Area Solar Radiation..." try: # Execute AreaSolarRadiation outGlobalRad = AreaSolarRadiation(inRaster, latitude, skySize, timeConfig, dayInterval, hourInterval, "NOINTERVAL", zFactor, "FROM_DEM", calcDirections, zenithDivisions, azimuthDivisions, "UNIFORM_SKY", diffuseProp, transmittivity, outDirectRad, outDiffuseRad, outDirectDur) except: print "Error while processing solar radiation" print (arcpy.GetMessages()) # Save the output outGlobalRad.save("D:/Projects/Tasks/02_SpatialInputs/SolarRad/work/MayJulyOutput/globrad") print "Finished" print time.asctime(time.localtime())
Tue Jan 28 09:52:16 2014
Executing: AreaSolarRadiation
/Projects/Tasks/02_SpatialInputs/SolarRad/work/MayJulyOutput\AreaSol_elev1 37.1567 200 "MultiDays 2012 121 212" 14 1 NOINTERVAL 1 FROM_DEM 32 8 8 UNIFORM_SKY 0.3 0.5 # # #
Start Time: Tue Jan 28 09:52:16 2014
ERROR 999999: Error executing function.
Failed to open raster dataset
Failed to execute (AreaSolarRadiation).
Failed at Tue Jan 28 09:53:33 2014 (Elapsed Time: 1 minutes 17 seconds)
