I'm having an issue using dojox.layout.FloatingPane. I create the floating pane using the following code: // add popup floating pane var dock = new dojox.layout.Dock({ id: 'dock', style: 'position:absolute; bottom:0; right:0; height:500px; width:0px; display:none; z-index:0;' }, dojo.create('div', null, dojo.body())); //find size of the map so to get the best possible initial size for the user var popX = map.width; var popY = map.height - 30; pFloatingPane = new dojox.layout.FloatingPane({ title: "Download Menu", resizable: true, //allow resizing closable: false, //we never want to close a floating pane - this method destroys the dijit dockable: true, // yes we want to dock it dockTo: dock, style: 'position:absolute;top:100px;right:10px;width:275px;height:375px;visibility:hidden;z-index:999 !important', id: "pFloatingPane" }, dojo.create('div', null, dojo.body())); dojo.connect(pFloatingPane, 'onFocus', function () { dijit.byId('pFloatingPane').bringToTop() }); //do the same for onShow dojo.connect(pFloatingPane, 'onShow', function () { dijit.byId('pFloatingPane').bringToTop() }); pFloatingPane.startup();When you click on a button, the floating pane is made visible on the map. pFloatingPane.attr("content",downloadString); pFloatingPane.show();Everything works fine. The floating pane displays all the content it is suppose to. The problem I have is after I close the pane and then click on the button to open it again, its height increases. In fact it keeps increasing every single time you reopen the floating pane. Am I missing something that controls the size of the pane? I'm using the following stylesheets: <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dojox/layout/resources/FloatingPane.css"/> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dojox/layout/resources/ResizeHandle.css"/> .dojoxFloatingPane { padding: 0 0 20px 0 !important; border: solid 1px #769DC0 !important; font-family: Arial, "Kimberley", sans-serif; font-size: 14px; } .dojoxFloatingPaneTitle { border: none; padding: 5px 0 10px 8px; height: 16px; background: #ABD6FF url('http://ajax.googleapis.com/ajax/libs/dojo/1.6/dijit/themes/claro/images/titlebar.png') repeat-x; } .dojoxFloatingPaneContent { border-top: solid 1px #769DC0; font-family: Arial, "Kimberley", sans-serif; font-size: 12px; } .dojoxFloatingMinimizeIcon { width: 15px; height: 15px; margin-right: 6px; padding-right: 6px; background: url('http://ajax.googleapis.com/ajax/libs/dojo/1.6/dijit/themes/claro/images/dialogCloseIcon.png') no-repeat 0 0; }Thanks for any assistance.
