Hi all,I'm having problems with the Measurement widget. When I attempt to use it, the lines aren't drawn between the markers, but vertically downwards instead. Hard to describe, so I attach a screenshot:[ATTACH=CONFIG]34242[/ATTACH]I'm use Alaska state plane coordinates for my operational layers, but a web mercator base map, so my map's spatial reference is web mercator too. I know I need to instantiate a Geometry service in esri/config/defaults, which I have done, and when I step through my code in Firebug I can see that the Measurement widget's _geometryService property is populated correctly.The code I use to instantiate the widget is simple enough:this.measure = new Measurement({
map : this.map,
defaultAreaUnit : (this.configOptions.units === "metric") ? "esriSquareKilometers" : "esriSquareMiles",
defaultLengthUnit : (this.configOptions.units === "metric") ? "esriKilometers" : "esriMiles",
}, 'measureDiv');
this.measure.startup();
I'm using the ArcGIS Server API for JavaScript v3.9.Any suggestions would be greatly appreciated as I'm stuck and past deadline! 😮Mark
