Hello!I'm using Flash Builder 4.5 Premium and ArcGIS API for Flex 2.5.Scenerio:I have a buttonBar whose dataProvider is an mx:viewStack supplied by Spark NavigatorContent. I have checkBoxes inside each of the NavigatorContent instances. The checkBoxes turn content on and off. Works great.Problem:When you select a different button in the buttonBar the selected content from the previuos button still displays.Question:How do I get the selected content from the previous button to not display? I'm not sure how to do this. Bonus:If someone can tell me how to handle the checkBox eventHandler more efficiently that would be awesome! Because right now I currently have an eventHandler function for each check box (like 18). Since I'm still green, so I figured I'd get everything working before trying to streamline this. Or perhaps I need to add something to this code to unSelect the checkBox once the button has changed? Not sure.Thanks for the help!Joe<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" xmlns:mx="library://ns.adobe.com/flex/mx" pageTitle="Aloha Existing Conditions" initialize="initApp(event)"> <fx:Style source="alohaExistingCond.css"/> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.components.Editor; import com.esri.ags.components.Legend; import com.esri.ags.events.FeatureLayerEvent; import com.esri.ags.events.LayerEvent; import com.esri.ags.geometry.MapPoint; import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; import com.esri.ags.layers.DynamicMapServiceLayer; import com.esri.ags.layers.TiledMapServiceLayer; import com.esri.ags.layers.supportClasses.LayerInfo; import com.esri.ags.layers.supportClasses.LayerLegendInfo; import com.esri.ags.layers.supportClasses.LegendItemInfo; import com.esri.ags.tasks.supportClasses.AddressCandidate; import flash.events.Event; import flashx.textLayout.events.UpdateCompleteEvent; import mx.containers.TitleWindow; import mx.controls.Alert; import mx.core.IFlexDisplayObject; import mx.events.FlexEvent; import mx.managers.PopUpManager; import mx.rpc.AsyncResponder; import spark.components.Panel; import spark.events.IndexChangeEvent; import splash1.SplashScreen1; public function initApp(event:FlexEvent):void { // showWindow(); } private var point1:Point = new Point(); private function showWindow():void { var login:SplashScreen1 = SplashScreen1(PopUpManager.createPopUp(this, SplashScreen1 , true)); PopUpManager.centerPopUp(login); } public function turnonbasemap():void { photo.visible = false; basemap.visible = true; } public function turnonphoto():void { [ photo.visible = true; basemap.visible = false; } //these are the checkBox Handlers public function bintBox(evt:MouseEvent):void { myLegend.visible = true; if(CheckBox(evt.target).selected) { bikelaneMapServer.visible = true; } else { bikelaneMapServer.visible = false; } } public function sintBox(evt:MouseEvent):void { sidewalkMapServer.visible = true; if(CheckBox(evt.target).selected) { } else { sidewalkMapServer.visible = false; } } public function scomBox(evt:MouseEvent):void { sidewalkComments.visible = true; if(CheckBox(evt.target).selected) { } else { sidewalkComments.visible = false; } } public function bcomBox(evt:MouseEvent):void { bikelaneComments.visible = true; if(CheckBox(evt.target).selected) { } else { bikelaneComments.visible = false; } } public function opsBox(evt:MouseEvent):void { OPS.visible = true; if(CheckBox(evt.target).selected) { } else { OPS.visible = false; } } ]]> </fx:Script> <!-- Button Bar Window ~~~~~~~~~~~~~~~ --> <s:BorderContainer id="buttonBarContainer" left="352" right="3" top="64" height="134" borderWeight="2" cornerRadius="5"> <s:Label text="Select an item below:" x="10" y="10"/> <s:ButtonBar id="viewMenu" left="5" right="5" top="30" height="21" dataProvider="{myViewStack}" requireSelection="true"/> <!-- change="changeSelection(event)" --> <s:Group id="layerGroup" left="5" right="3" top="55" height="80"> <mx:ViewStack id="myViewStack" height="72"> <s:NavigatorContent id="planning" label="Planning"> <s:layout> <s:TileLayout paddingLeft="10" paddingRight="20" orientation="columns" columnWidth="175" requestedColumnCount="-1"/> </s:layout> <s:CheckBox id="bCommentCheckBox" label="Bike Lane Comment" fontSize="14" click="bcomBox(event)"/> <s:CheckBox id="foo1" label="Foo 1" fontSize="14"/> <s:CheckBox id="foo2" label="Foo 2" fontSize="14"/> <s:CheckBox id="foo3" label="Foo 3" fontSize="14"/> <s:CheckBox id="foo4" label="Foo 4" fontSize="14"/> </s:NavigatorContent> <!-- trans tab ~~~~~~~~~~~~~~--> <s:NavigatorContent id="trans" label="Transportation"> <s:layout> <s:TileLayout columnWidth="175" orientation="columns" paddingLeft="10" paddingRight="20" requestedColumnCount="-1"/> </s:layout> <s:CheckBox id="sCommentCheckBox" label="Sidewalk Comments" fontSize="14" click="scomBox(event)"/> <s:CheckBox id="sidewalkCheckBox" label="Sidewalk Inventory" fontSize="14" click="sintBox(event)"/> <s:CheckBox id="bikelaneCheckBox" label="Bike Lane Inventory" fontSize="14" click="bintBox(event)"/> </s:NavigatorContent> <s:NavigatorContent id="environ" label="Environmental"> <s:layout> <s:TileLayout paddingLeft="10" paddingRight="20" orientation="columns" columnWidth="200" requestedColumnCount="-1"/> </s:layout> <s:CheckBox id="opsCheckBox" label="Watershed Enhancement" fontSize="14" click="opsBox(event)"/> </s:NavigatorContent> <s:NavigatorContent id="housing" label="Housing/Social"> <s:layout> <s:TileLayout paddingLeft="10" paddingRight="20" orientation="columns" columnWidth="175" requestedColumnCount="-1"/> </s:layout> <s:Label text="Housing and Social Services Maps"/> </s:NavigatorContent> <s:NavigatorContent id="built" label="Built Environment"> <s:layout> <s:TileLayout paddingLeft="10" paddingRight="20" orientation="columns" columnWidth="175" requestedColumnCount="-1"/> </s:layout> <s:Label text="Built Environment Maps"/> </s:NavigatorContent> <s:NavigatorContent id="transit" label="Transit"> <s:layout> <s:TileLayout paddingLeft="10" paddingRight="20" orientation="columns" columnWidth="175" requestedColumnCount="-1"/> </s:layout> <s:Label text="Tansit Maps"/> </s:NavigatorContent> </mx:ViewStack> <!--<s:Label id="selectionText" x="10" y="60"/> --> </s:Group> </s:BorderContainer> <esri:ArcGISTiledMapServiceLayer id="basemap" url="http://........Washco_primary_basemap_SP/MapServer"/> <esri:ArcGISTiledMapServiceLayer id="photo" url="http://......../Orthos_2010_SP/MapServer" visible="false"/> <esri:ArcGISDynamicMapServiceLayer id="bikelaneMapServer" name=" " visible="false" url="http://........services/DOE/DOE_Bikelane/MapServer"/> <esri:ArcGISDynamicMapServiceLayer id="sidewalkMapServer" name=" " visible="false" url="https://........DOE/DOE_Sidewalk/MapServer"/> <esri:ArcGISDynamicMapServiceLayer id="OPS" name=" " visible="false" url="http://........OPS/Watershed_Enhance/MapServer"/> <esri:FeatureLayer id="sidewalkComments" mode="snapshot" visible="false" url="http://........DOE/SidewalkComment/FeatureServer/0"/> <!-- outFields="[Comment, entered]" --> <esri:FeatureLayer id="bikelaneComments" mode="snapshot" visible="false" url="http://........BikelaneComment/FeatureServer/0"/> <esri:GraphicsLayer id="myGraphicsLayer"/> </esri:Map> </s:Application>
