A newbie (me) would love some geoprocessing, model building guidance. Conceptual advice is appreciated. I also have 2 specific questions: a) What tools are best to create my outputs? 2) Do I need to pre-process the layers since they are in different formats (polygons, xy data, etc.)? Many many thanks!Outputs1) Show polygon areas on African map when ALL of the following criteria are met�?� Water depth = �??Shallow�?� �?� Population density = between x and y people per km�?� Land usage = �??Rainfed mixed crops�?� or �??rainfed corn�?� or �?� (I will select 20 out of 73 categories)2) # of people that live in those polygon areas, broken out by countryMY MAP LAYERSWATER DEPTHThis shows water depth categories at various points in Africa (shallow, very shallow, etc.). I started with an XY table and converted it into a shape file. Info from Properties:Data Type: Shapefile Feature Class
Shapefile: C:\Users\T. Hardy Jackson\Documents\Consulting\KickStart\GIS\KickStartGIS\WaterDepth.shp
Geometry Type: Point
Coordinates have Z values: No
Coordinates have measures: No
Geographic Coordinate System: GCS_WGS_1984
Datum: D_WGS_1984
Prime Meridian: Greenwich
Angular Unit: Degree
POPULATION DENSITYThis shows population density at particular points (500 people / km at long xyz.xyz and lat xyz.xyz, etc.)Columns and Rows: 2160, 1920
Number of Bands: 1
Cell Size (x,y): 0.0416666667, 0.0416666667,
Format: BIL
Source Type: Generic
Pixel Type: Unsigned integer
Pixel Depth: 32 Bit
NoData Value:
Pyramids: level: 3, resampling, Nearest Neighbor
Spatial Reference: Undefined
LAND USAGEShows how land is being used at various areas in Africa (73 categories)Columns and Rows: 40322, 19446
Number of Bands: 1
Cell Size (x,y): 0.089281971, 0.089281971
Format: GRID
Pixel Depth: 8 Bit
NoData Value: 255
Pyramids: level: 7, resampling, Nearest Neighbor
Spatial Reference: GCS_WGS_1984
Angular Unit Degree (0.01745�?�..)
Datum: D_WGS_1984
AFRICA COUNTRY MAPShows country borders.Data Type: Feature Service Feature Class
Location: http://services.arcgis.com/MdapRpkzb0PVHqL1/arcgis/rest/services/Africa_Noll/FeatureServer
Feature Class: 1
Feature Type: Simple
Geometry Type: Polygon
Datum: D_WGS_1984
