Field Domains in ArcPro and AGOL
Has anyone found a way to carry over domains defined in AGOL feature classes (data field editor) into the symbology for that layer loaded in an ArcPro project map? The attributes show up but during the symbolization process only the codes display. I set the coded value domains up in AGOL in the data field editor. Different results depending on whether you load the individual feature dataset layer or a web map with the features symbolized by the domain field.
The map symbology only works with the symbology in the web map. For example, we worked up a trees layer with fields 'status' and 'species' in a 'tree survey' web map. If the web map symbology is for 'status' with domains: 1, Healthy [Green dots] ; 2, Dying [Red dots] that layer comes in ArcPro fine with the correct labels. If you try and change the symbology of that layer for 'species', you are stuck with the code values in the domain, with no definition.
