Hi Gurus,
we are using ArcGIS collector version 10.7.2 , got error when trying to download map as a normal user. Following is the details :
I have setup an web map in ArcGIS online with Offline mode enabled , all the feature service layers in this web map has “Enable Sync” mode checked. I have created a group "Testing" in my organisation, setup a test user who is the member on that group, I share the web map and map services to that group. When users trying to download map in the device got the following errors :
“You do not have permissions to access this resource or perform this operation”
As an administrator , I can download the same map using collector , but as normal user got the above mentioned error.
Is there any setting I missed here ?
it will be great help , if anyone can give any clue.
With regards,
Shafey
