I am new to writing code and need help displaying a Google basemap (hybrid) in a web map built on the ArcGIS Javascript API. I have a Google Maps API key, which was removed for this example. I used the documentation at http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.00/docs/googlemapslayer/examples.html as a guide, but I am stuck. Any help would be greatly appreciated!
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title></title>
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css" />
<link rel="stylesheet" href="css/layout.css"/>
<script>
var djConfig = {
parseOnLoad: true,
packages: [{
"name": "agsjs",
"location": 'https://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/xbuild/agsjs' // for xdomain load
</script>
<script src="http://maps.google.com/maps?file=api&v=3&key=" type="text/javascript"></script>
<script src="http://js.arcgis.com/3.8/"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("agsjs.layers.GoogleMapsLayer");
dojo.require("dijit.layout.TabContainer");
dojo.require("esri.dijit.Legend");
var map, googleLayer;
function init() {
map = new esri.Map("map", {
center: [-82.65862, 29.820309],
zoom: 16
googleLayer = new agsjs.layers.GoogleMapsLayer({
apiOptions: {
v: '3'
map.addLayer(googleLayer);
dojo.ready(init);
</script>
</head>
<body class="claro">
<div id="mainWindow"
data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline', gutters:false"
style="width:100%; height:100%;">
<div id="header"
data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
Tool
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="leftPane" data-dojo-props="region:'left'">
<div data-dojo-type="dijit.layout.TabContainer">
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend', selected:true">
<div id="legendDiv"></div>
</div>
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Identified Issues'" ></div>
</div>
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
<div id="footer" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'"></div>
</div>
</body>
</html>
Thank you!Matt
