I'm pretty new to using arcpy for spatial analysis. I'm trying to run the Euclidean distance analysis and keep getting the following error: ERROR 000622: Failed to execute (Euclidean Distance). Parameters are not valid.
ERROR 000628: Cannot set input into parameter cell_size. I'm entering an integer value for this parameter so I am confused why I keep getting this error. Here is my code:
#Import system modules
import arcpy, os
from arcpy import env
from arcpy.sa import *
#Set environment settings
ws = os.getcwd()
arcpy.env.workspace = ws
#Set local variables
in_source_data = "lrt_stop"
cell_size = 100
distance_method = "PLANAR"
#Execute EucDistance
outEucDist = EucDistance(in_source_data, cell_size, distance_method)
#Save output
outEucDist.save("Ltr_Dist")
