I have this simple code but the polyline is not drawing. The answer, I suspect is simple...but not for a novice in js. Thanks.
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title></title>
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.7/js/esri/css/esri.css">
<style>
html, body, #map {
height: 100%; width: 100%; margin: 0; padding: 0;
</style>
<script src="//js.arcgis.com/3.7/"></script>
<script>
var map;
require([
"esri/map",
"esri/geometry/Point",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/graphic",
"esri/geometry/Polyline",
"esri/SpatialReference",
"esri/layers/GraphicsLayer",
"dojo/domReady!"
], function(
Map, Point, SimpleMarkerSymbol, SimpleLineSymbol, Graphic, Polyline, SpatialReference, GraphicsLayer
map = new Map("map", {
basemap: "streets",
center: [-122.16,37.7238],
zoom: 10
map.on("load", function() {
var gl = new GraphicsLayer();
var myspatialref = new SpatialReference({wkid:102100});
var p = new Point((-122.159, 37.724),new SpatialReference(102100));
var t = new Point((-122.169, 37.721),new SpatialReference(102100));
var coords=[];
coords.push([p,t]);
var polyline = new Polyline(myspatialref);
var polylineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0xFF3333,1,3);
polyline.addPath(coords);
var polylineGraphic = new Graphic(polyline, polylineSymbol);
gl.add(polylineGraphic);
map.addLayer(gl);
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
