I'm attempting to better understand the AGS token service and cannot seem to get thru some errors (probably something simple I'm missing). For starters, I simply just want to generate a token for a secured feature service and see it as a string/console. That's it.
Here's my sample that is hitting the error "Method not supported" in the console.log(error.message)….
<SPAN class="keyword token">var</SPAN> tokRequest <SPAN class="operator token">=</SPAN> <SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://myAGS/tokens/generateToken"</SPAN><SPAN class="punctuation token">,</SPAN>
method<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"post"</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
f<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN><SPAN class="punctuation token">,</SPAN>
username<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"myUsername"</SPAN><SPAN class="punctuation token">,</SPAN>
password<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"myPassword"</SPAN><SPAN class="punctuation token">,</SPAN>
referer<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"<https://myAppPageURL>"</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Success: "</SPAN><SPAN class="punctuation token">,</SPAN> response<SPAN class="punctuation token">.</SPAN>toJson<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>error<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Error: "</SPAN><SPAN class="punctuation token">,</SPAN> error<SPAN class="punctuation token">.</SPAN>message<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//<--error hits here</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any help is appreciated.
