How can I export a file geodatabase to csv table using python running a script from inside a map document.Got the following code from Mathew Coyle off this forum and ran it but it did not work for me.Other ideas? import arcpy from os import path as p fc = "C:\\Test\\Test.gdb\\Test1" CSVFile = "C:\\Test\\Test1" def TableToCSV(fc,CSVFile): fields = [f.name for f in arcpy.ListFields(fc) if f.type <> 'Geometry'] with open(CSVFile, 'w') as f: f.write(','.join(fields)+'\n') #csv headers with arcpy.da.SearchCursor(fc, fields) as cursor: for row in cursor: f.write(','.join([str(r) for r in row])+'\n') print 'Created %s Successfully' %p.basename(CSVFile)
