Hi everyone,I am trying to use IPolycurve.QueryPointAndDistance to get the distance from the curve start to the location of a dam on a river.The problem I encountered is that this seems to query existing vertices on the river, so if the particular segment has only a start and end point (and no vertex near the dam location), the distance to the dam will always be 0.In order to get around this I am using IProximityOperator.ReturnNearestPoint to find the point on the river closest to the dam, and then using IPolycurve.SplitAtPoint to create a vertex at that point. Once that vertex is in place, QueryPointAndDistance should be able to measure the distance to that vertex.Now, the SplitAtPoint method has a boolean output called SplitHappened and this is set to "True" when the split is successful.I am running through this loop for 5 different dams. For the first one, SplitHappened is set to "False" and the distance to the dam is 0. But for the other 4 dams, SplitHappened is set to "True". I don't know what could be changing between the first iteration and the others to cause this difference.Any comments will be appreciated
'Create a point on the river nearest the dam
Dim pProxOp As IProximityOperator
Set pProxOp = pRiver ' <--- pRiver is an IFeature
Dim pDamPoint As IPoint
Set pDamPoint = pProxOp.ReturnNearestPoint(pDam, esriNoExtension) '<-- pDam is an IFeature
'Create a vertex in the river at that point
Dim PartIndex As Long
Dim SegIndex As Long
Dim SplitHap As Boolean
pRiver.SplitAtPoint pDamPoint, True, False, SplitHap, PartIndex, SegIndex
Debug.Print SplitHap ' <-- This comes up "False" the first time, and "True" all other times
'Find the distance to the point
Dim DistToDam As Double
Dim NearDist As Double
Dim Length As Double
Dim pDamPoint2 As IPoint
Set pDamPoint2 = New Point
Dim Right As Boolean
pRiver.QueryPointAndDistance esriNoExtension, pDam, False, pDamPoint2, DistToDam, NearDist, Right
