Where is some good documentation of how many map or feature services to create from 1 SDE feature class and the effect it has on rendering speed, instances (max out instances), editing ect.
For example can I increase instances and free up the server when I create 4 map services (each with 4 instances) from 1 feature class?
Should I create copies of the same feature class and publish separate map services for each web mapping application (1 feature class, 1 map service cosumed by 1 web mapping application) or is that not necessary?
Or how does having the 1 map service consumed in 3 web mapping applications effect instances?
