I am testing a script that will append PDF files together into a sngle document. The script performs as exspected until it hits the line pdfDoc.saveAndClose and then it throws a syntax error. It actually creates the combined PDF on disk even though it is throwing the error. What is wrong ith this syntax?import arcpy import os from os.path import isdir, join, normpath, split mxd = arcpy.mapping.MapDocument("Current") wPath = r"Y:\Notification Radius Pkgs\dave500\\" RequestID = "Dave Jordan" try: pdfPath = wPath+RequestID+".pdf" arcpy.AddMessage(pdfPath) if os.path.exists(pdfPath): os.remove(pdfPath) #Create the file and append pages pdfDoc = arcpy.mapping.PDFDocumentCreate(pdfPath) for file in os.listdir(wPath): if file.endswith(".pdf"): arcpy.AddMessage("Adding "+file) pdfDoc.appendPages(wPath+file) #Commit changes and delete variable reference pdfDoc.saveAndClose() del pdfDoc except Exception, e: import traceback map(arcpy.AddError, traceback.format_exc().split("\n")) arcpy.AddError(str(e))
