I'm having a hard time managing my selected rows in my dGrid. I read that the default selection mode is already set to extended. I have an event on dgrid-select that fire my chart function and that works. I'd to be able to select mutiple rows from the grid to generate a chart with the information from multiple rows, but I'm having a hard time managing the selection. As soon as I select one row, my chart gets generated.
I am creating my grid based on a featureLayer,queryFeatures. Here's the result handler.
function gridHandler(results) {
var rateTest, countTest;
var returnObj = {};
domConstruct.empty(dom.byId('gridDiv'));
var gridColumns = buildColumns();
var data = arrayUtils.map(results.featureSet.features, function(feature){
return feature.attributes;
grid = new (declare([Grid, Selection]))({
columns: gridColumns
}, "gridDiv");
grid.renderArray(data);
grid.sort('County');
grid.on("dgrid-select", function(event){
var rows = event.rows;
var row = event.rows[0];
var gridQuery = new Query();
gridQuery.objectIds = [row.data.OBJECTID];
featureLayer.selectFeatures(gridQuery, FeatureLayer.SELECTION_NEW, function(results) {
if ( results.length > 0 ) {
// createLineChart(results);
createLineChart(results[0]);
var feature = results[0];
feature.setInfoTemplate(infoTemplate);
var resultGeometry = results[0].geometry;
map.infoWindow.setFeatures(results);
// map.infoWindow.show(resultGeometry.getExtent().getCenter()); //assume geometry is a polygon
} else {
console.log("error in grid.on click function");
dom.byId("gridText").innerHTML = title+ " - " + currentYear;
//creates a column definition for the grid based on the attributes returned from the query
function buildColumns() {
var columns = [];
//qryOutFields is an array of fieldNames defined earlier
arrayUtils.forEach(qryOutFields, function(field){
var objects = {};
objects.label = field;
objects.field = field;
if (field === 'OBJECTID') {//assumed name for internal ID from map service
objects.hidden = true;
columns.push(objects);
return columns;
