I am using a proxy to consume some secured layers in ArcGIS Javascript API. Everything is working fine locally, meaning when the machine is inside LAN
When accessing it through DMZ the application produce a pop-up from the Arcgis Server for Authentication (username, password). It works fine when supplied the credentials. But not going through proxy. producing the following error:-
How can I solve this pplease ???
[SocketException (0x274c): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 00.00.00.00:6080]
System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) +185
System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) +496
[WebException: Unable to connect to the remote server]
System.Net.HttpWebRequest.GetResponse() +1399
proxy.doHTTPRequest(String uri, String method, NetworkCredential credentials) +243
proxy.getNewTokenIfCredentialsAreSpecified(ServerUrl su, String reqUrl) +947
proxy.ProcessRequest(HttpContext context) +3086
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +188
System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +48
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +71<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
