I am consuming this service for Railroad crossings.
When I put it in my app it renders the labels when the layer is turned off.
When I turn it on it still shows them.
I cant seem to turn them off....I want them to turn off when I turn the layer off.
Layer: Rail Crossings (ID: 0)
Any thoughts? I am trying to below but nothing seems to work.
window<SPAN class="punctuation token">.</SPAN>RailroadCrossings <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"https://fragis.fra.dot.gov/fragis/rest/services/FRAGradeXing/MapServer/0"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_ONDEMAND<SPAN class="punctuation token">,</SPAN>
showLabels<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
onStatusChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>status <SPAN class="operator token">=</SPAN> Enums<SPAN class="punctuation token">.</SPAN>LayerStatusInitialized<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
enableLabels <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> infoTemplateRailroadCrossings<SPAN class="punctuation token">,</SPAN>
id<SPAN class="punctuation token">:</SPAN><SPAN class="string token">"RailroadCrossing"</SPAN><SPAN class="punctuation token">,</SPAN>
definitionExpression<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">" StateCode='51' AND POSXING='1' "</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I also tried to showLabels as false on the map itself but then no other labels show up...I have them true in this example
window<SPAN class="punctuation token">.</SPAN>map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"gray"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">77.980586</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">37.566286</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN>
logo<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
showLabels <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
